Mowing 72" mid mount auto connect issues
/ 72" mid mount auto connect issues #1
Halakennels
Luxemburg
John Deere 3520 compact
I have a 2011 3520 compact with cab
Running a auto connect 72" mid mount deck.
Have been experiencing the bolts on pro bearing housing shearing off and recently the bracket bolt holes are so wore out that it is completely inoperable without extreme wobble,vibration and noise.
My question is this,
Does anyone know if JD makes a manual pto shaft that connects this deck to tractor by manual connect and disconnect as I always end up in and out of tractor several times to "auto" connect anyhow. If so what is part number and specs for this shaft..?
Wish JD would revamp this aotuconnect pto design as it seems mostly flawed.
Thank you for any assistance anyone scan give.
/ 72" mid mount auto connect issues #2
:welcome: to TBN
Can't give you an answer, but hope that another member will have some help.
That would be frustrating... might look in jdparts
John Deere - Parts Catalog
for a drive shaft.. go to model 3520 then to implements and find your 72" deck .. appears to be straight drive shaft as well as the auto connect.
Thank you for reply.
Did talk with local dealer, just can't believe how much they are getting for a simple manual DS. Checking on auto connect part prices as well
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
