72" bent bucket edge (need advice)
   / 72" bent bucket edge (need advice)
I have thought of having a new edge welded on!
   / 72" bent bucket edge (need advice) #12
   / 72" bent bucket edge (need advice) #14
Find a stump about 2-3 feet tall, flip the bucket over and put the top of the bent area on the stump. That will support the bucket while you use the sledge.
   / 72" bent bucket edge (need advice) #15
Cut a slice through the worst part of the bend so the metal has a place to go. Weld it back up after you have it straight.
   / 72" bent bucket edge (need advice) #16
Just for what it's worth. To me, using steady pressure is ALWAYS better than a hammer at almost any stuck or bent thing.
I have on ocassion drilled holes in work where one couldn't get a puller, clamps or a vice on. Then used bolts or threaded rod to pull the thing back into position. Finally, weld the holes closed and grind them up pretty again.
   / 72" bent bucket edge (need advice) #17
Yep, agree with this method. You need to take out a bit of the "stretched material".
   / 72" bent bucket edge (need advice) #18
Making a sawcut through the bend also allows you to work half the material at a time. Better to move a corner than flatten an arch.
   / 72" bent bucket edge (need advice) #19
Cut out the bent piece and weld in a new piece.
   / 72" bent bucket edge (need advice) #20
The slice it, heat it, real big hammer, then a new weld on cutting edge.
Brent 420 Grain Cart (A55301)
Brent 420 Grain...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
Mobile toilet (A53424)
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A52706)
2019 CATERPILLAR...
New Kivel 3500 lb. Skidloader Forks (A50775)
New Kivel 3500 lb...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2015 FREIGHTLINER...
