72" bent bucket edge (need advice)
   / 72" bent bucket edge (need advice)
I have thought of having a new edge welded on!
   / 72" bent bucket edge (need advice) #12
   / 72" bent bucket edge (need advice) #14
Find a stump about 2-3 feet tall, flip the bucket over and put the top of the bent area on the stump. That will support the bucket while you use the sledge.
   / 72" bent bucket edge (need advice) #15
Cut a slice through the worst part of the bend so the metal has a place to go. Weld it back up after you have it straight.
   / 72" bent bucket edge (need advice) #16
Just for what it's worth. To me, using steady pressure is ALWAYS better than a hammer at almost any stuck or bent thing.
I have on ocassion drilled holes in work where one couldn't get a puller, clamps or a vice on. Then used bolts or threaded rod to pull the thing back into position. Finally, weld the holes closed and grind them up pretty again.
   / 72" bent bucket edge (need advice) #17
Yep, agree with this method. You need to take out a bit of the "stretched material".
   / 72" bent bucket edge (need advice) #18
Making a sawcut through the bend also allows you to work half the material at a time. Better to move a corner than flatten an arch.
   / 72" bent bucket edge (need advice) #19
Cut out the bent piece and weld in a new piece.
   / 72" bent bucket edge (need advice) #20
The slice it, heat it, real big hammer, then a new weld on cutting edge.
2009 Ford F-150 Crew Cab Pickup Truck (A55788)
2009 Ford F-150...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
UNUSED LANDHONOR LHR-G209 ANCHOR SHACKLES (A54757)
UNUSED LANDHONOR...
2015 Ford Taurus SE Sedan (A55853)
2015 Ford Taurus...
2013 Ford F-150 Pickup Truck (A53422)
2013 Ford F-150...
2019 John Deere 204L (A47477)
2019 John Deere...
