Backhoe 710 B Turbo
/ 710 B Turbo #1
Jthomas88
JD 710 B backhoe
I have a backhoe that will start and run for approx. 1 minute, sometimes more and then it starts exhuasting blue smoke and then dies. I have dumped the old fuel and replaced it with fresh, changed the fuel pump and filter. Next I blew air through the fuel injector return line that goes back to the tank, to make sure thers no restriction. Took the top off the injector pump to be sure the silinoid is working correct. When it starts and runs , it seems fine, the exhaust is clean while its running, but then it will start exhausting blue smoke and then dies , it doesn't make an difference how much throttle you give it. I have even thought about pulling the turbo off to be sure it not locking up ? I put a piece of PVC to the turbo and other end to my ear , and sounds O.K. I didn't hear a loud bearing sound. The next thing is possibly removing the injector pump and getting it rebuilt, but I would like to know that that's the problem before I spend the money . Any HELP would be GREAT. Thanks J.T.
/ 710 B Turbo #2
I'm far from a mechanic but i believe your feul system is ok.I would check your oil system cou8ld be the return from the head is plugged but i think you would see oil coming out somewhere or maybe the oil system to the turbo if the turbo has scattered or simillar.Careful if it is the turbo or cracked head you could make matters much worse by running the engine.
2015 Kubota RTVX1100C (A62177)
2015 Kubota...
2012 Ford Expedition SUV (A61574)
2012 Ford...
2014 Freightliner 105' Bucket Truck (A63689)
2014 Freightliner...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
40in. Skeleton Bucket Excavator Attachment (A61567)
40in. Skeleton...
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
