7 Pin Trailer Plug
/ 7 Pin Trailer Plug #1
cjoffutt
North Central IN
Kioti NX5010 HST
Does anyone know which pin is ground and 12v? Trying to wire up a trailer connector to use my 3 point sprayer via the 7 Pin, but none appear to be supplying power. I'm assuming the large pin at 12 o'clock is ground?
Either that or I'm missing a fuse that will let the 7 Pin work. The pig tail on the tractor side goes to some other wire harness right between the rear tires, then to the rops lights and goes under the seat area.
/ 7 Pin Trailer Plug #2
Do they even supply AUX 12 volts to the connector on your tractor? Information for 7 pin is all over the internet. Ground in center, but if you didn't find the live (maybe with key on) ,maybe it's not there.
Who knows if they did... I assumed they did since it appears to be wired in best I can tell.
But after testing earlier with key on, and then tractor running I doubt it. There isn't a fuse labeled for trailer plug, closest thing is 'user power' but it doesn't even have the metal clip for the fuse to lock into.
Was mainly just wanting to make sure I wasn't missing something simple before I ran wires from the battery back to it myself.
/ 7 Pin Trailer Plug #4
That would be a shame if they didn't. But hey, it's another three dollars worth of copper.
/ 7 Pin Trailer Plug #6
Here is a generic diagram. Unknown if it's what you need:
/ 7 Pin Trailer Plug #7
Boy, I got that wrong. I thought the center was ground! Maybe thinking the Flat RV plug.
Come to find out, 12v isn't supplied to the plug on the tractor side at all. Rather lame in my opinion.
Guess I'll find an unused fuse slot in the block next to seat or use one of the 'add a fuse' things. Not a real easy clean way to run wires from the battery all the way to the back.
/ 7 Pin Trailer Plug #9
There is two types of 7 pin trailer plugs. they look the same but the pins are different. For running lights, brake, indicators a 7 pin `N` type is used. For auxiliary a 7 pin `S` type is used. The wiring for this is as you look at the `plug`, at pin 4, 6 o clock, is a 12v supply. Number 3 pin, at 7.30, is the common return.
/ 7 Pin Trailer Plug #13
Funny, I just unsubscribed to E-Trailer. Bought one dammm thing from them (over the phone) and they have been E-Mailing me daily since !!!!!!!!!!!! Terrible business practices!
/ 7 Pin Trailer Plug #14
Looking at the posts on here, it seems we do things a bit different to you guys on this side of the pond. For normal `autos` we use the two seven pin plugs or the latest one thirteen pin plug. Heavy `trucks` have a different size plugs.
/ 7 Pin Trailer Plug #15
I think I have found references to at least 4 different ways to wire up a 7 pin plug. None of the ones shown in this thread match what I have on my truck!!??
/ 7 Pin Trailer Plug #16
It can get confusing with diagrams showing the front or the back of the socket, and the front or the back of the plug.
And in some that appear different, the pin function is the same, but the color coding is different.
Bruce
Long story short, per the manual there isn't a 12v supply to any of the pins.
To remedy this issue, I just added a 10 amp fuse to the block next to the seat, ran a wire to the tractor side plug and a ground as well. I wasn't concerned about messing up the random pinout it already had as I'll never pull a trailer down the road with the tractor, that's what the truck is for. But if I ever need to, all I have to do is remove the 12v supply and put the original wire back in.
Sprayed about 50 gallons of roundup this morning with no issues at all.
/ 7 Pin Trailer Plug #18
Here lies one if the big problems with answering your question. There is no universal standard for a 7 pin connector. There are at least 2 standards for these plugs.
Maybe this will help. The 7 way here is the RV standard. No guaranty yours is wired this way however.
/ 7 Pin Trailer Plug #19
Then on top of that some tractors will actually have the European type plug and pinout.
2015 FREIGHTLINER M2 24FT REFRIGERATED CDL REQUIRED BOX TRUCK (A59914)
2015 FREIGHTLINER...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
Valley Pivot Point (A64127)
Valley Pivot Point...
2006 Peterbilt C15 (A64127)
2006 Peterbilt C15...
Freightliner Tender Truck - Adams Tender (A63688)
Freightliner...
