7' Blower on TC33DA??
   / 7' Blower on TC33DA?? #1
wvrocks
Tucker Co, WV
TC-33 DA
just like the title says, will a TC33DA handle a 7' rear mounted snowblower?
I have a chance to buy one for about $1000 in very good condition. Has hydraulic rotation. I'm cleaning a 1/3 mile gravel driveway that has some drifting problems. Biggest drift is usually about 2-3 feet deep and 100 yards long. I've been using a 7' rear blade but the driveway gets narrow pretty quickly and requires a lot of loader time to push the edges back.
   / 7' Blower on TC33DA?? #2
You don't normally get to much snow there but I'd not recommend it even with a hydro for the versatility of the speed incase you might get a good snow. The other thing that might be a problem is the weight of it.
Yeah, I was concerned about the weight. The 3pt is rated at 1635lbs @24 inches back. As far as snow, we get a good bit. Nothing like New England but usually about 150-200 inches a year. We get a fair amount of lake effect off of Erie. Most events are 3-6 inches, although its not uncommon to get a 10-12" in a storm, usually a couple dumps of a foot or more each season. Typically for me, drifting is a bigger problem than the actual amount of snowfall.
   / 7' Blower on TC33DA?? #4
I think that's an awfullly big blower for a TC33. I'd try to get a 5 footer if it was me.
Andy
I think you are probably right, and I was kind of leaning that direction before I posted. Thanks for your advice.
   / 7' Blower on TC33DA?? #6
You can always slow down, but judging by how yesterday's heavy 12" of snow was bogging my 4' blower on my TC18, I'd say it is too big. A 6 footer would be about right if you don't get big dumpings of snow often.
The better question is - Should I upgrade to a TC45DA so I can run my new 7' blower...:D :D :D
Good idea, except I'd have to upgrade to a bigger barn to keep it in and probably a new wife as well.......
   / 7' Blower on TC33DA?? #8
I run a Woods SS74 (which is just a bit over 6') on my TC33D. I don't think it's too big at all. If the snow is deep, or really dense I have to slow down a bit, but it does a very nice job.
   / 7' Blower on TC33DA?? #9
A 5 foot wide snowblower would be too small. It wouldn't be wide enough to cover your TC33DA tire tracks.
I run a Meteor 75 inch (6 ft, 3 inch) wide blower with no problem on my TC33DA. As others have said, just slow down in deep or wet snow.
I don't know what the 7 foot blower you're considering weighs, but I can't imagine it exceeding the capacity of your 3PH. My very slightly smaller unit only weighs 680 lbs.
2025 Swict 72in Bucket Skid Steer Attachment (A50322)
2025 Swict 72in...
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,400LB 3 Ton Crane Service Truck (A50323)
2013 Ford F-550...
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
2007 DEUTZ D 2011L03 MOTOR (A52472)
2007 DEUTZ D...
