# 7 backhoe cylinders
/ # 7 backhoe cylinders #1
mnatalie
John Deere 755 subcompact
I have a 755 with a # 7 backhoe. The cylinders that swing boom left and right leak. The front of the cylinders, (towards the tractor) have the supply lines connected, the distal end (away from tractor) has what appears to be a piece of old rubber hose cut off and this is where they leak when operated. My question is: What should the distal end be connected to? Each other? or just capped off? :confused:
Thanks
mnatalie
Thanks
mnatalie
Thank you for your reply.
mnatalie
Thanks, just bought this unit and have ordered the owner's manual.
/ # 7 backhoe cylinders #4
Welcome to TBN:D
Are you a dentist? The only time I here the term "distal" is at the dentist!
Anyway, K7 is 100% correct. See the diagram from JDParts below. I think the hose you are reffering to is #16.
Oh, and I asked a Moderator to more your post to the regular JD forum.
/ # 7 backhoe cylinders #5
Aren't those single acting cylinders ? Is there supposed to be fluid in the back end ?
Chris
/ # 7 backhoe cylinders #6
Chris
Yes, they are SA cylinders. Some leaking may be expected since the cylinders are older, but if they still have the power to operate the swing then rebuilding them is a waste of money.
I'm not a dentist, but do work in the medical field, sorry. Thanks for the diagram, I have been looking for resources like this. The backhoe is in very good shape except for the severed, (I mean cut) hydro line. I have many projects lined up for the 755 and plan to build a cab this winter. I'm new to the forum and my posting has been moved twice already. Not sure where it should be, but at least I know someone is reading it if they move it.
Mike
/ # 7 backhoe cylinders #8
The JD parts system is free, all you have to do is register and "think like a parts guy" to use it. It is the same basic system the dealers use at the parts counter. There is a quick tutorial linked in my signature to help if you need it.
www.jdparts.com
Landhonor Mini Skid Steer Rock Grapple (A62679)
Landhonor Mini...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63689)
2021 Takeuchi...
Wolverine Quick Attach Tiller (A66285)
Wolverine Quick...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
Metal Bigfoot Lawn Art (A61574)
Metal Bigfoot Lawn...
