#7 back hoe attachment on the JD 770 Tractor
   / #7 back hoe attachment on the JD 770 Tractor #1
kartvines
Need help, installed the backhoe onto my JD 770 tractor, it was tricky being I have never done it before, After installing it I have been unable to keep the inner locking slot locked. The #7 attaches using two slots, the rear ones under the PTO and an inner locking set just inside the rear tires. Each time I tried to use the back hoe the bar slides out of the inners locking slots, I guess they may be broken. I have no plans on ever removing the backhoe attachment, so I thought that I would have the slot locks tacked welded to keep the bar in place so I can get use the back hoe. Has any one ever welded this area and does it hold? Welcome feed back. /forums/images/graemlins/confused.gif
   / #7 back hoe attachment on the JD 770 Tractor #2
Sounds more likely something isn't being properly locked in place than damaged. Don't think I'd be doing any welding. Do you have a manual. I have one for the #7, but not sure if it covers the 770. I'll look if I remember.
I have the book and it does show how the bar is locked into the slots, and I check to make sure everything is locked, but they must be damaged, because they do not keep the bar tight in the slot, they become dislodged.
1998 6X12 Utility Trailer (A56859)
1998 6X12 Utility...
Unused 84" Bucket Attachment (A55272)
Unused 84" Bucket...
2017 Freightliner M2 106 Terex Commander C4047 Insulated Digger Derrick Truck (A55973)
2017 Freightliner...
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A57453)
2016 Hino 195h...
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
