6ft Bush Hog Question
/ 6ft Bush Hog Question #1
hayesj3
Mount Juliet Tn
Massey Ferguson 245
I need to replace grease fittings on a Bush Hog brand 6ft anyone have any idea what size I need to buy?
/ 6ft Bush Hog Question #2
Can you not use the old ones to know the size? I will guess with all the models Bush Hog has made there could be more than one size used and also where on the cutter they are. They also have rough cut and finish mowers.
I have a Bush Hog rear finishing mower and think the fittings on the wheels are std 1/8 pipe threads (think have the 1/8) right. Think those on my spindles are same but I want to move to longer ones to make greasing easier. No idea on the pto shaft.
/ 6ft Bush Hog Question #3
I ended up buying a set of like 100 grease fittings in both SAE and metric. Buying a kit was a lot cheaper than buying them one or two at a time.
2015 RAM 4500 HD 4x4 Service Truck (A62613)
2015 RAM 4500 HD...
New/Unused Quick Attach Rock Hammer (A61166)
New/Unused Quick...
2012 Range Rover SUV (A61569)
2012 Range Rover...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
DURA-CAST PRO-LICK TANK (A62131)
DURA-CAST PRO-LICK...
1762 (A58375)
1762 (A58375)
