680e case backhoe has know forward or reverse wont move
   / 680e case backhoe has know forward or reverse wont move #1
toolguy1975
680e case
680e case backhoe wont move in forward or reverse
   / 680e case backhoe has know forward or reverse wont move #2
Welcome to TBN.
Did you hear any noises when it stopped moving? I think you might have a broken flex plate, #45.
   / 680e case backhoe has know forward or reverse wont move #3
Have you checked the clutch cut out switch (on loader handle) and/or shuttle spool valve ?
Welcome to TBN.
no noise just got in and nothing i guess its a neutral safety switch on dash that says forward and neutral on it you can flip it back and forth and theirs like know resistance kinda looks like it would work off air but i hant removed it yet
theirs no switch on loader handle its on the dash pannel
no not yet i need to get a manual the clutch cut out is mounted by gauges on dash dont know aboutshuttle spool valve
can you bypass neutral safety switch
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
10ft x 8ft Container with Side Door (A51573)
10ft x 8ft...
Under Body Toolbox (A51573)
Under Body Toolbox...
2006 Kobelco SK210LC Hydraulic Excavator (A52377)
2006 Kobelco...
