680e case backhoe has know forward or reverse wont move
   / 680e case backhoe has know forward or reverse wont move #1
toolguy1975
680e case
680e case backhoe wont move in forward or reverse
   / 680e case backhoe has know forward or reverse wont move #2
Welcome to TBN.
Did you hear any noises when it stopped moving? I think you might have a broken flex plate, #45.
   / 680e case backhoe has know forward or reverse wont move #3
Have you checked the clutch cut out switch (on loader handle) and/or shuttle spool valve ?
Welcome to TBN.
no noise just got in and nothing i guess its a neutral safety switch on dash that says forward and neutral on it you can flip it back and forth and theirs like know resistance kinda looks like it would work off air but i hant removed it yet
theirs no switch on loader handle its on the dash pannel
no not yet i need to get a manual the clutch cut out is mounted by gauges on dash dont know aboutshuttle spool valve
can you bypass neutral safety switch
UNUSED CFG QK16R EXCAVATOR (A51247)
UNUSED CFG QK16R...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A53472)
Neckover GL24-2-7K...
2006 CATERPILLAR 330DL EXCAVATOR (A51246)
2006 CATERPILLAR...
1999 Case 850G Crawler Tractor Dozer (A51691)
1999 Case 850G...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
