68 JD 400 hydraulics acting up.HELP!
   / 68 JD 400 hydraulics acting up.HELP! #1
Oldchevyguy
1968 John Deere 400
I have a 1968 JD400 backhoe and it’s been a great machine. Recently I was noticing a slight delay in engagement letting the clutch out before it got rolling and every now and then the loader would act a little jerky. It has a few minor leaks so I figured it was probably just a little low on fluid. Last weekend I started it up and it didn’t want to drive at all. I checked the fluid and it was on the add mark. I dumped some in and it was still a little low so I put in more and it was up to the mark. Now it wanted to move but was still a little sluggish on the take off. I shut it off and when I came back about an hour later it seemed normal. I chalked it up to need air to work out or something. Yesterday I drove it to my brothers house about a mile away all told and on the way the power steering didn’t work. Then after I got there it started working and but the loader was not working right, going slow and didn’t want to pick up. At one point that got better but then the backhoe inplaments started acting up and didn’t want to work but then the backhoe loader was good and the machine wanted to move forward and backwards. Now I’m really scratching my head. Today the drive engage was super slow and the loader and the power steering were taking turns throwing fits. I’m at a loss. Has anyone had this experience? I’m wondering if it could be the filter? I don’t get why it is playing musical chairs with the different functions. If nothing works I would believe a plugged up filter or a bad pump but you would expect it to be all or nothing not taking turns between the different functions.
   / 68 JD 400 hydraulics acting up.HELP! #2
Try a new filter also clean the sump screen if it has one.
   / 68 JD 400 hydraulics acting up.HELP! #3
I believe that model loader backhoe had the variable volume piston pump with load sense or pilot control. It could be that the pilot control is randomly getting a pressure signal or some crud is stuck in it.
Do you have equipment to take any pressure readings for diagnostic purposes?
I do not . I have a lot of friends who are diesel mechanics and regular mechanics and I know a transmission guy, so it’s possible that I could get my hands on something. Where and how would I connect a gauge to get a pressure reading? Where would the pilot control be? Does that seem more likely than clogged filters or sump screen?
A quick search on the internet and AI says that is not the type of pump that machine has. It does show replacement pumps and they are not described as variable volume. I have a parts machine with a new pump if the pump was the issue. When the implements are working there is no lack of power. They just take turns not working.
   / 68 JD 400 hydraulics acting up.HELP! #6
Before even considering replacing any hyd pump one should perform the easiest tasks first. It doesn't get much easier than changing the hyd filters & checking cleaning the hyd oil suction screen.
Next I suggest to perform good hyd diagnostic procedures before entertaining the thought of replacing any hyd pump!!!
Photo below is for an ag not ind tractor but round cannister holds 1 hyd filter & 2nd hyd filter is located near by.
JD 400 ind tractor has closed center 8 piston hyd pump in front of radiator with an internal stroke control valve that controls hyd pressure. If stroke control valve gets some foreign material in stroke control valve seating area it will affect system hyd pressure.
   / 68 JD 400 hydraulics acting up.HELP! #7
I had a 1970 JD 400 that had issues with the loader, it would work fairly well, although a little slow, until the oil heated up, then it would hardly lift at all. The backhoe and stabilizers worked like a champ. I tried everything I could think of, re manufactured hydraulic pump, rebuilt the diverter valve etc. I had the JD mechanic out to go over it and he was stumped.
About 2 weeks before I sold it, I read something about the steering valve having priority, taking pressure away from the loader. I removed the steering column and had a guy that worked at JD rebuild it as a side job. After I reinstalled the steering column, the loader worked like new.
This may be your answer too.
   / 68 JD 400 hydraulics acting up.HELP! #8
As you determined replacing hyd components more especially frt hyd pump without performing good hyd diagnostic procedures isn't as good idea.
Several JD utility tractor steering valves have been known to have failed o-rings causing hyd problems. Simple hyd test is disconnect power steering supply line & cap pressure line orifice then check operation of hyd system.
Any large internal hyd leak can cause closed center hyd to not operate correctly.
2014 Bolens 11A-020W765 20in Push Mower (A55973)
2014 Bolens...
UNVERFERTH 18' FIELD CULTIVATOR (A52708)
UNVERFERTH 18'...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
JEEP FOR DOUBLE TRAILER (A58214)
JEEP FOR DOUBLE...
2024 CATERPILLAR 259D3 SKID STEER (A52709)
2024 CATERPILLAR...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
