3-Point Hitch 6520 hydraulic pulley
   / 6520 hydraulic pulley #1
ScottRFoster
Jacksonville, FL
Ferguson F40
The pulley on the hydraulic pump is cracked - is this the correct replacement?
I ask because the one pictured doesn't look right - no splined hub shown and holes to attach this part look wrong
   / 6520 hydraulic pulley #3
Correct it doesn't look right. Maybe call or email them ....
Has any one else had this problem and bought the part in the catalogue - or able to provide pics of their 20 series hydraulic pump pulley for comparison?
Thanks
   / 6520 hydraulic pulley #5
Scott,
It looks like you removed the pulley mounting hub in the second photo. The pulley is held on with 4 bolts to the hub. Just take the pulley to your Mahindra dealer. I had mine replaced, when it cracked in warranty, in one day.
I just went out in the dark and took this photo.Mahindra Hyd Pulmp Pulley.jpg
hugs, Brandi
   / 6520 hydraulic pulley #6
Now I am thinking straight. I just remembered I had it all on CD. Look at the smaller window in the diagram. Mine, and looks like yours...........is Exculsive For Extended Camshaft. Item #22 is where the pulley mounts with 4 each item #24. I do remember the bolts are m8.
The * number just above item 2 is the sub assy main drive pulley. As you can see there are 2 groove pulleys and a single grove pulleys. We have the single groove pulley.Hyd. Pump Diagram.jpgHyd. Pump Parts Callout.jpg I think item 22 is what you took off in your second photo and didn't need to do that.
Bottom line, take the old part to a Mahindra dealer. Part numbers have changed numerous times over the years since this CD was made.
hugs, Brandi
Scott,
hugs, Brandi
You totally rock.
Ya I removed the splined hub... this part will need to be attached to the new pulley
   / 6520 hydraulic pulley #9
You sure about that? My pulley is changed by loosening the belt and removing 4 bolts. That is all.
hugs, Brandi
   / 6520 hydraulic pulley #10
You totally rock.
Thanks. I have lost count how many times I have gone out in the cold, dark night to take photos for folks on TBN. My pleasure. How close are you to a Mahindra dealer?
hugs, Brandi
KJ 8'x6' Powder Coated Steel Site Fence (A50121)
KJ 8'x6' Powder...
1994 Alumatech Frameless Dump Trailer (A50514)
1994 Alumatech...
Generac 92A03400-S (A47384)
Generac 92A03400-S...
Polecat Swift 206R 20ft Towable Boom Lift (A50322)
Polecat Swift 206R...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
