6500 problem
/ 6500 problem #41
Yes, a full tank reduces condensation and keeps the tank coated with diesel to prevent rust.
So, how important is fresh fuel?
Does it not deteriorate over time? How long can a tank be left in there and still perform?
In our humid climate, we have issues with algae also.
If diesel remains in the tank for a year, with just incremental amounts added a couple times during that year, what kind of issues will that cause?
Are some of the additives ok to use? keep the cetane up, prevent algae, remove water, etc.
I use Power Service Diesel Fuel Supplement +Cetane Boost.
HAPPY NEW YEAR hugs, Brandi
/ 6500 problem #42
Was confident enough today to disasssemble the fuel line system. Now, I have some questions about how pumps, valves and flow work.
Should I be able to blow air, like blowing a kid's balloon, in th direction of fuel flow?
/ 6500 problem #43
Same year and same issue here... contamination in the tank. Did you ever remove the tank... and if so, are there instructions anywhere? Thanks!
/ 6500 problem #45
Did you ever get your fuel issue solved! Got an interesting fix from a dealer! Have not tried it yet but fixing to!
40ft High Cube Shipping Container (A64553)
40ft High Cube...
40ft 10 Door Shipping Container (A64194)
40ft 10 Door...
LONG 10 WHEEL V-RAKE (A64278)
LONG 10 WHEEL...
Metaltech climb and go (A64553)
Metaltech climb...
Karcher G 2800 OC Portable Pressure Washer (A64553)
Karcher G 2800 OC...
MAN BASKET (A64553)
MAN BASKET (A64553)
