6500 problem
/ 6500 problem #41
Yes, a full tank reduces condensation and keeps the tank coated with diesel to prevent rust.
So, how important is fresh fuel?
Does it not deteriorate over time? How long can a tank be left in there and still perform?
In our humid climate, we have issues with algae also.
If diesel remains in the tank for a year, with just incremental amounts added a couple times during that year, what kind of issues will that cause?
Are some of the additives ok to use? keep the cetane up, prevent algae, remove water, etc.
I use Power Service Diesel Fuel Supplement +Cetane Boost.
HAPPY NEW YEAR hugs, Brandi
/ 6500 problem #42
Was confident enough today to disasssemble the fuel line system. Now, I have some questions about how pumps, valves and flow work.
Should I be able to blow air, like blowing a kid's balloon, in th direction of fuel flow?
/ 6500 problem #43
Same year and same issue here... contamination in the tank. Did you ever remove the tank... and if so, are there instructions anywhere? Thanks!
/ 6500 problem #45
Did you ever get your fuel issue solved! Got an interesting fix from a dealer! Have not tried it yet but fixing to!
Bobcat Skidsteer (A60352)
Bobcat Skidsteer...
6 Row Harrell Stalk Chopper (A62177)
6 Row Harrell...
(1) New 7ft Chain Sling (A61166)
(1) New 7ft Chain...
BUNDLE OF (1) TOPLINK & (2) LIFT ARMS (A62130)
BUNDLE OF (1)...
UNUSED ATS 4'X300' GRASS PROOF CLOTH (A62131)
UNUSED ATS 4'X300'...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
