6500 problem
/ 6500 problem #41
Yes, a full tank reduces condensation and keeps the tank coated with diesel to prevent rust.
So, how important is fresh fuel?
Does it not deteriorate over time? How long can a tank be left in there and still perform?
In our humid climate, we have issues with algae also.
If diesel remains in the tank for a year, with just incremental amounts added a couple times during that year, what kind of issues will that cause?
Are some of the additives ok to use? keep the cetane up, prevent algae, remove water, etc.
I use Power Service Diesel Fuel Supplement +Cetane Boost.
HAPPY NEW YEAR hugs, Brandi
/ 6500 problem #42
Was confident enough today to disasssemble the fuel line system. Now, I have some questions about how pumps, valves and flow work.
Should I be able to blow air, like blowing a kid's balloon, in th direction of fuel flow?
/ 6500 problem #43
Same year and same issue here... contamination in the tank. Did you ever remove the tank... and if so, are there instructions anywhere? Thanks!
/ 6500 problem #45
Did you ever get your fuel issue solved! Got an interesting fix from a dealer! Have not tried it yet but fixing to!
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
2016 Ford F-250 Crew Cab Pickup Truck (A64556)
2016 Ford F-250...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
New/Unused Landhonor Gantry Crane (A65583)
New/Unused...
(INOP) INTERNATIONAL 1066 TRACTOR (A64278)
(INOP)...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
