6430 performance question
   / 6430 performance question #1
drkllr
john deere 6430
I have 6430 premium I have to say one of the best tractors i have owned. reciently i got a #2 injector mechanical misfire. checked everything everything good run for another couple of hours came on again. checked everything everything works as advertised. ??????? we are figureing that i got some trash in it. The question is has anybody heard of issuses with the injectors just to set my mind at ease
   / 6430 performance question #2
I bought my 6415 used. It came with service records. At 1086 hours the number two injector started leaking and a cap for it was replaced under warranty. Hope tis helps.
how was the leak determined was it visable was there fuel in the oil or was it pulled and the crack found just wanting to know what to look for
   / 6430 performance question #4
I was not the owner when this happened. I did get the service records when I bought it used.
They state: customer says leaking fuel on engine.
"Tech steamed engine to find leak. Found #2 injector leaking at cap area. Replaced Injector cap. Recleaned. Tested"
Parts listed:
1 RE531438 kit $6.94
1 TY26101 brake/clutch ( I am guessing a spray brake cleaner) $4.94
Labor @ $69.00 per hour:
2 hours repair
.75 hours diagnose
Hope this helps. Leak must have been visable, Nothing about diesel in the oil, don't know if Injector was pulled.
Thanks that does make since i will check that out
   / 6430 performance question #6
I hope I have no need to worry, I'm having delivered on Monday, the new 6330 I bought, not a premium but pretty premium to me compared to my old 630 2 cylinder!! I'd get sick if an injector acted up real soon.
It had to be a hickup 10 hrs on tractor since then smooth as silk. must have been trash. I love this tractor it thinks it is 150hp It does so much more than it should. Ive been told it should not pull a 21ft disk with 20" blades. It does in c range with no problem it pulls 12' bog 30" blades dealer said it would not do that. 9" chisel with 32" teeth you cant pull that boy this tractor does i think you will be very happy. Pound for pound best tractor i have had.
   / 6430 performance question #8
That's quite a move up! I got a 6X15 series which is the economy version of the 6X20 series and its PREMIUM to the 2030 it will replace.
   / 6430 performance question #9
The tractors 125 Hp. But your ground is really dry and your disk looks light.
tractor is rated at 115hp it thinks it is 150. ground is dry that field had not been worked in 30 yrs i did a ton of work on it 1st turned it with 5 bottom plow then ran the disk to smooth. then ran chisel in t patern over the whole field then ran disk again with 25' i beam drag you can see behind the disk the field was very rough i over worked it on purpose to smooth i then ran packer on it before planting first cut produced 1.75 tons acre prior to rework .40 tons acre the dealer still claims it should not pull the eguipment i have been pulling i just smile pat it on the tire tell em big john dont know it cant it just does.
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
Truck bed (A51692)
Truck bed (A51692)
