hozjob
Having an issue with my 6410. The problem began with the reverser not working correctly, it would only go into reverse and when I put it to forward it also would beep and go in reverse. I shut it down and now nothing happens when I turn the key to start it. It appears that it thinks it's not in neutral and won't allow it to start? I've jumped the starter, and it will start and run fine, plenty of power in the battery and all the hydraulics work correctly once running... just won't move. When I switch the reverser to move forward or reverse it just beeps. Checked the solenoids under the tranny all have similar Ohm readings, swapped out the neutral pressure switch as well. Any ideas??
