6410 JD power reversing
   / 6410 JD power reversing #1
randyvire
clarksville ar
6410 johndeere
I just purchase a 6410 JD /1999 year it has a left hand power reverser lever and it will not stay engaged, it will engage but as so as the tractor moves the lever falls back into neutral position. If you hold the lever in the forward or reverse position the tractor work great. Does anyone know what is gong on with this.
Thanks
Randy
   / 6410 JD power reversing #2
Hi, Randy. Welcome to the forum!
I'm going to move your thread over to our John Deere section to see if we can find you an answer.
   / 6410 JD power reversing #3
:welcome: to TBN
Does it look like this schematic? Maybe the springs don't hold the lever in the notch.. just a guess, after looking at jdparts.
John Deere - Parts Catalog
That is not my power reverser
My is part number Re 70840
   / 6410 JD power reversing #5
Post a pic of yours.. pls
   / 6410 JD power reversing #7
Maybe this? shows the "lever" with control box.. might need replacement..
A new level is around 900.00 dollars so I was trying to make sure there was not anything else that would cause the issue. I had read that were a alot of lever change out and was not the issue. Do you know if there is any type of safety switch that could cause it to drop out of gear or a relay , solenoid valve
   / 6410 JD power reversing #10
G'day must be the season for this I have a 6310 at work at the moment with the same problem have been told it could be a trans pressure switch or a park switch will get a chance to look Monday will let you know what we find
Jon
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A53473)
2006 Magnolia Dry...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A53473)
Kubota SVL65-2...
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
2008 Hitachi PC228 (A47477)
2008 Hitachi PC228...
