64 ford 2000 4cyl gas hydraulic lift system
   / 64 ford 2000 4cyl gas hydraulic lift system #1
glynn patterson
good hope ga
ford 2000
hydraulic lift will not pick up. removed upper housing from lower to see if piston was stuck.it appears to be at least i cant move it.is there a way to free it up. ive tapped on it with a wood mallet with no luck. is there any other common reason for this to happen. also i have replaced all o rings
   / 64 ford 2000 4cyl gas hydraulic lift system #2
REMOVE CHECK VALVE AND BLOW AIR . DONT STAND IN FRONT WHEN APPLYING AIR AS THE PISTON WILL HURT YOU.
thanks to coyotemag im ready to bush hog again. thanks again
   / 64 ford 2000 4cyl gas hydraulic lift system #5
very probably the unloader valve stuck. it's a common issue.
if this happens again.. post back before taking the top cover off. :)
i have removed unloader valve cleaned and replaced o ring. control valve,piston& all spools associated with it.all o rings have been replaced. will be installing lift plate soon will let you know. thanks for input
   / 64 ford 2000 4cyl gas hydraulic lift system #7
lets see what ya got.
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2016 FREIGHTLINER...
2016 VOLVO EC380EL EXCAVATOR (A51246)
2016 VOLVO EC380EL...
(APPROX 18) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 18) 2" X...
2017 Wanco WSDT Towable Compact Radar-Speed Trailer (A52377)
2017 Wanco WSDT...
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
