64 ford 2000 4cyl gas hydraulic lift system
   / 64 ford 2000 4cyl gas hydraulic lift system #1
glynn patterson
good hope ga
ford 2000
hydraulic lift will not pick up. removed upper housing from lower to see if piston was stuck.it appears to be at least i cant move it.is there a way to free it up. ive tapped on it with a wood mallet with no luck. is there any other common reason for this to happen. also i have replaced all o rings
   / 64 ford 2000 4cyl gas hydraulic lift system #2
REMOVE CHECK VALVE AND BLOW AIR . DONT STAND IN FRONT WHEN APPLYING AIR AS THE PISTON WILL HURT YOU.
thanks to coyotemag im ready to bush hog again. thanks again
   / 64 ford 2000 4cyl gas hydraulic lift system #5
very probably the unloader valve stuck. it's a common issue.
if this happens again.. post back before taking the top cover off. :)
i have removed unloader valve cleaned and replaced o ring. control valve,piston& all spools associated with it.all o rings have been replaced. will be installing lift plate soon will let you know. thanks for input
   / 64 ford 2000 4cyl gas hydraulic lift system #7
lets see what ya got.
2013 New Holland T4.75 Tractor (A52384)
2013 New Holland...
2015 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A51691)
2015 John Deere...
2016 INTERNATIONAL MA025 BOX TRUCK (A53426)
2016 INTERNATIONAL...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A53473)
UNVERFERTH 330 8...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2007 Ford F-350 9FT Stakebody Flatbed Truck (A51691)
2007 Ford F-350...
