64 ford 2000 4cyl gas hydraulic lift system
   / 64 ford 2000 4cyl gas hydraulic lift system #1
glynn patterson
good hope ga
ford 2000
hydraulic lift will not pick up. removed upper housing from lower to see if piston was stuck.it appears to be at least i cant move it.is there a way to free it up. ive tapped on it with a wood mallet with no luck. is there any other common reason for this to happen. also i have replaced all o rings
   / 64 ford 2000 4cyl gas hydraulic lift system #2
REMOVE CHECK VALVE AND BLOW AIR . DONT STAND IN FRONT WHEN APPLYING AIR AS THE PISTON WILL HURT YOU.
thanks to coyotemag im ready to bush hog again. thanks again
   / 64 ford 2000 4cyl gas hydraulic lift system #5
very probably the unloader valve stuck. it's a common issue.
if this happens again.. post back before taking the top cover off. :)
i have removed unloader valve cleaned and replaced o ring. control valve,piston& all spools associated with it.all o rings have been replaced. will be installing lift plate soon will let you know. thanks for input
   / 64 ford 2000 4cyl gas hydraulic lift system #7
lets see what ya got.
UNUSED AGT TSOCPF48 MAST W/ 48" FORKS (A51248)
UNUSED AGT...
2018 John Deere 310L 4x4 Extendahoe Loader Backhoe (A52377)
2018 John Deere...
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
PORTABLE UP RIGHT FUEL TANK (A51248)
PORTABLE UP RIGHT...
