6330 lower link arm operation question
/ 6330 lower link arm operation question #1
hotchkiss
Ohio
JD 6330, JD 5055e, Ford 4000,
I just got a new 6330 and yes I know I need to post photos to prove it at some point. For now, bear with me please. I was looking through the manual and the options for draft control, the settings, etc. are numerous to to say the least. Can someone give me brief tutorial on what really works for you. For me, I generally need to raise the links and lower them. I do know I can control the speed at which the arms raise and lower. Other than that, what features are really of benefit. The manual talks about locking the arms to prevent pitching when transporting attachments.
/ 6330 lower link arm operation question #2
Keep the draft links bunjee corded together when not hooked on to an implement. Having them swinging around can damage your tires or the load Sensor that operates the draft control. I use it when plowing sometimes but not always. Otherwise you have a rate of drop dial and a height control dial to the rear of the control. Use the rate of drop to keep implements from crashing down. I don't really use height control except for w a big long 3 pt harrow w baskets. I keep it as close to the ground as practical in case I pop a wheelie on steep headlands. Or at least ill set it like that when training new operators. Best of luck. Great tractor.
2004 CHEVROLET MALIBU 4 DOOR CAR (A66091)
2004 CHEVROLET...
PALLET OF TOOLBOXES (A68842)
PALLET OF...
Caterpillar D330 4 Cylinder Power Unit (A64912)
Caterpillar D330 4...
PILES OF TARPS (DIMENSIONS UNKNOWN) (A68842)
PILES OF TARPS...
2018 Chevrolet Tahoe SUV (A66738)
2018 Chevrolet...
2014 BOMAG BW 211D-50 SMOOTH DRUM ROLLER (A67714)
2014 BOMAG BW...
