Mowing 62C mower deck, stripped blade bolt
   / 62C mower deck, stripped blade bolt #1
chipsndust
Platinum Member
central NY and Adirondacks
JD 1025R, Curtis cab
Has anyone had this problem?
I lost the left blade (side opposite discharge) while mowing. Found the blade, washer, and bolt (next to a rock I hit).
By using a thinner washer for a temporary fix, I was able to get enough threads to catch so I could finish mowing. I can't tighten the bolt with the washer that's supposed to be on there.
I can't tell if the threads in the spindle are stripped (probably are).
Do I need to replace the whole spindle?
Looks like a longer bolt would hold, if I could find one.
Before I take it to the dealer, I thought I would run it by the collective genius of the forum to see if anyone has had to deal with this problem.
   / 62C mower deck, stripped blade bolt #2
shaft is avail alone for less than $30, I'd replace it if it was mine, hate to see a blade come off at the wrong moment!
   / 62C mower deck, stripped blade bolt #3
Yep. :ashamed:
Thanks guys.
I called the dealer, they have the spindle and bolt in stock. I think that's all I need.
Went to the dealer and bought spindle (AM127432, $22.95) and bolt (19M7872, $.99).
Fairly easy repair, with the deck off, take the belt off the pulley, loosen the nut on top of the pulley, drive the old spindle out.
I installed the blade on the new spindle before install, it makes it easier to tighten the nut on top of the pulley. The new spindle includes a zerk.
Took a lot of grease in the new spindle.
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
2022 Adams CLC-1013 Conveyor - New (A52748)
2022 Adams...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52748)
2016 Ford F550 4x4...
Toro Zero Turn (A50324)
Toro Zero Turn...
Kidd 450 Straw Chopper (A50774)
Kidd 450 Straw...
ATTENTION PLEASE READ (A50120)
ATTENTION PLEASE...
