Mowing 62C mower deck, stripped blade bolt
   / 62C mower deck, stripped blade bolt #1
chipsndust
Platinum Member
central NY and Adirondacks
JD 1025R, Curtis cab
Has anyone had this problem?
I lost the left blade (side opposite discharge) while mowing. Found the blade, washer, and bolt (next to a rock I hit).
By using a thinner washer for a temporary fix, I was able to get enough threads to catch so I could finish mowing. I can't tighten the bolt with the washer that's supposed to be on there.
I can't tell if the threads in the spindle are stripped (probably are).
Do I need to replace the whole spindle?
Looks like a longer bolt would hold, if I could find one.
Before I take it to the dealer, I thought I would run it by the collective genius of the forum to see if anyone has had to deal with this problem.
   / 62C mower deck, stripped blade bolt #2
shaft is avail alone for less than $30, I'd replace it if it was mine, hate to see a blade come off at the wrong moment!
   / 62C mower deck, stripped blade bolt #3
Yep. :ashamed:
Thanks guys.
I called the dealer, they have the spindle and bolt in stock. I think that's all I need.
Went to the dealer and bought spindle (AM127432, $22.95) and bolt (19M7872, $.99).
Fairly easy repair, with the deck off, take the belt off the pulley, loosen the nut on top of the pulley, drive the old spindle out.
I installed the blade on the new spindle before install, it makes it easier to tighten the nut on top of the pulley. The new spindle includes a zerk.
Took a lot of grease in the new spindle.
Generac 9GA03104-5 (A47384)
Generac 9GA03104-5...
2003 Lexus LS 430 Sedan (A50324)
2003 Lexus LS 430...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
Crate of New Hydraulic Hoses (A47384)
Crate of New...
2014 Chevrolet Cruze (A50324)
2014 Chevrolet...
