6210 Rock Shaft Problem
/ 6210 Rock Shaft Problem #1
Believer
I've got a 6210, 1999 vintage. After running awhile, the rock shaft does not want to lift. I'll stop and work the control for what seems like 30-60 seconds, and suddenly it lifts. Then a while later, same thing. When it works, it works completely correctly. When it doesn't work, it drops but won't lift. Any ideas? Thanks.
/ 6210 Rock Shaft Problem #2
I'm not very familiar with JD tractors built after the 55 series but I think the rockshaft is electronically controlled. If so this part(AL116824 HITCH CONTROLLER),wiring or switch could be the culprit.
/ 6210 Rock Shaft Problem #4
When it fails to raise, have you tried the fender switch? Have you tried both controls in cab?(slide control and rocker switch). If none of the switches work, then I would suspect wiring between the controller and the stepper motor.
/ 6210 Rock Shaft Problem #5
Either that.... or it's minus 21 degrees F and JD doesn't make a transmission heater!! :laughing: (That happened just last week! Toggle, rear fender, slide control - it didn't matter where or what I did.)
AKfish
