6110 cab AC
   / 6110 cab AC #1
PawpawScooter
Mahindra 6110 cab
Clutch locking up
Belt squealing….. belt is tight.
   / 6110 cab AC
Sorry first time user….. ac runs gets cold then belt starts squealing. Clutch locks up after running a few minutes.
   / 6110 cab AC #6
No I will do that..thanks
Actually, clean the condenser which will be under the hood and in front of the radiator and clean the radiator as well. I use Dawn dish wash detergent in a spritz bottle mixed with water after blowing them out with compressed air (at less than 50 psi because high pressure air will deform the fins. I actually clean everything under the hood every day I use the tractors with a battery powered blower (I use a Harbor Freight Bauer, hand held 20 volt blower). Cheap and work quite well.
Then clean the evaporator (don't know where yours is located at), mine is over my head, under the removable roof.
Land Honor Diesel Fuel Transfer Pump (A50515)
Land Honor Diesel...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2020 FREIGHTLINER M2 26FT BOX TRUCK (A52141)
2020 FREIGHTLINER...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
