61 john deere 4010 diesel injector pump problem.
   / 61 john deere 4010 diesel injector pump problem. #1
diesel4all
baker city, Oregon
J.D.4010
The diesel engine won't rev up, stars hard and dies when at idle. I pulled the pump and found the metering valve stuck and there had been water in the fuel. I got the valve unstuck after using penetrating oil. The spring on the valve linkage is rusty and I took it out. when I did this the spring and collars popped out with and I don't know their proper position so I need help with a diagram or directions to assemble it. I can't get the cross pin with throttle link on it apart. it must be corroded.I would like to get the pump completely apart to see if there is more trouble. Need help.
   / 61 john deere 4010 diesel injector pump problem. #2
Welcome to TBN. I wish I could help but I have very limited knowledge on the internal parts of an inj pump.
   / 61 john deere 4010 diesel injector pump problem. #3
Most likely the best chance for a diagram is a nearby JD dealer.. An even better option would be a tractor salvage yard! 'Cause you'll likely need to replace those corroded and rusty components, anyway. And you'll see exactly what goes where..
Good luck.
AKfish
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2015 Caterpillar D6K Crawler Tractor Dozer (A50322)
2015 Caterpillar...
1997 International F-4900 T/A Dump Truck (A50323)
1997 International...
2015 FREIGHTLINER M2 DAY CAB (A52141)
2015 FREIGHTLINER...
2020 Toro Workman HD Gasoline Utility Cart (A50322)
2020 Toro Workman...
Roose Hog Cart (A50515)
Roose Hog Cart...
