61 john deere 4010 diesel injector pump problem.
   / 61 john deere 4010 diesel injector pump problem. #1
diesel4all
baker city, Oregon
J.D.4010
The diesel engine won't rev up, stars hard and dies when at idle. I pulled the pump and found the metering valve stuck and there had been water in the fuel. I got the valve unstuck after using penetrating oil. The spring on the valve linkage is rusty and I took it out. when I did this the spring and collars popped out with and I don't know their proper position so I need help with a diagram or directions to assemble it. I can't get the cross pin with throttle link on it apart. it must be corroded.I would like to get the pump completely apart to see if there is more trouble. Need help.
   / 61 john deere 4010 diesel injector pump problem. #2
Welcome to TBN. I wish I could help but I have very limited knowledge on the internal parts of an inj pump.
   / 61 john deere 4010 diesel injector pump problem. #3
Most likely the best chance for a diagram is a nearby JD dealer.. An even better option would be a tractor salvage yard! 'Cause you'll likely need to replace those corroded and rusty components, anyway. And you'll see exactly what goes where..
Good luck.
AKfish
2014 Gleaner 3000-R8 Corn Head (A50657)
2014 Gleaner...
2005 PETERBILT 357 TRI AXLE DUMP TRUCK (A51222)
2005 PETERBILT 357...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2022 CATERPILLAR 306CR EXCAVATOR (A51242)
2022 CATERPILLAR...
2012 MACK CHU613 (A50854)
2012 MACK CHU613...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A51039)
Kubota BX2680...
