6030 or 6520
/ 6030 or 6520 #1
mark mcmanus
North Carolina
anyone outthere with an opinion on the difference?
scott in indiana are you out there-can you help with an idea on price and desirability on the two. thanks mark
/ 6030 or 6520 #2
I like the 6030 FEl , it weighs 6230lbs, has a large platform and 8x8 shuttle shift 4WD for $25,600 or so. The 6520 4WD with FEl goes for around $27,500. It weighs in @ 7300lbs. It does have 12x12 shuttle.
The extra gears on the 6520, more HP and weight, plus the fact the 6520 is not in its first year of production probably make it worth the extra 2K.
Also according to Mahindrauas.com the 6520 has a $1500 REBATE:)
/ 6030 or 6520
thanks for the reply Scott, I've found an 04 7520 with low hours and am wondering if there are any known issues regarding this model. mark
/ 6030 or 6520 #4
Nothing major that I am aware of. Lots of posts on here about them. Biggest you can get from Mahindra CURRENTLY :)
/ 6030 or 6520 #5
The 6520 has a large FULL platform. The 6520 also has heavy duty 3PH arms (see photo below) with sliding adjustments and also have telescoping tubes instead of check chains like the 6030 has. ;) If I didn't own a 6520, I would definitely buy the adjustable arms. The 12 speed is sweet also. I can put it in low 1st, hit the steering tilt and stand up and level dirt with the bucket. The 6520's 3PH will pick up around 1100 more pounds than a 6030. The 6520 uses the ML275 loader that lifts 3900 pounds up to just over 11 feet. Well worth the price deference. :) :D :cool: ;) Get the skid steer qucik attachment loader no matter what you end up buying.
hugs, Brandi
