60 rotary cutter input.
/ 60 rotary cutter input. #1
Jacksonvly
Kioti CK 2610
I am looking for a 60 cutter for my new Kioti. I was contemplating a finish mower as I will mainly be cutting lawn, maintained trails and field grasses around my acres of trees. Feel better going with a rotary, just in case.
Which model gives the best quality cut? I assume blade speed comes into play here??
/ 60 rotary cutter input. #2
None of them give a really great cut. The ones with 2 tail wheels will help improve the quality of the cut but it won't look like a subdivision lawn!
/ 60 rotary cutter input. #3
I would go with King Kutter with the Flex Hitch if you are not going to be mowing much rough stuff.
No subdivisions within 50 miles!
Looked at a Tarter square back at TSC, not super heavy duty, but I think it work work.
/ 60 rotary cutter input. #5
I find that if you keep the blades sharp they will do a pretty good job on grass if not to tall and mower is fairly close to ground . I have had a bush hog brand 6 ft. and now using a 5 ft. landpride . The RCR landpride will cut closer to the ground than the bush hog did . If cutting hay for example forget about a lawn looking appearance with a rotary cutter. The bush hog was a heavier duty unit . I do need a larger unit for my M5700 though . A finish mower will do a better job for sure on grass.
/ 60 rotary cutter input. #6
You can't cut tall 3 foot grass and leave it looking like a lawn with a bushhog but you can't with a lawnmower either. I'm amazed at how good of cut my landpride 8 footer gives if you just slow down a bit and cut it like a lawnmower would, as in from 8 inches down to 4. Looks plenty groomed from any distance. Of course as the blades get dull the cut goes downhill but so do the lawnmowers. I compared it to a SCAG turf tiger as far as cut goes and the Landpride did very well against it. Not as good but closer than move folks lead you to believe.
/ 60 rotary cutter input. #7
I have a 6ft Landpride finish mower that does a great job with my lawn. When grass gets thick and tall (over 1 ft) it bogs my tractor down a lot. Almost makes me wish I had more power... :)
A five footer would do better, and in heavy fields, probably the bush hog is better.
/ 60 rotary cutter input. #8
I have the county line 5 footer. It is fine for what it is. It will go over a 1.5 inch tree just fine. It is light duty. I mow horse pasture w it. Does just fine. I would not want it if I mowed for a living.
2023 John Deere 6R 175 Tractor (A63111)
2023 John Deere 6R...
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
2017 Ram 5500 Bucket Truck (A63689)
2017 Ram 5500...
John Deere Gator TX4x2 (A62177)
John Deere Gator...
1996 FRUEHAUF 45' SLIDING AXLE FLATBED TRAILER (A59911)
1996 FRUEHAUF 45'...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2019 FREIGHTLINER...
