Grading 60" Mower Blade Tip Speed.
/ 60" Mower Blade Tip Speed. #1
marrt
Platinum Member
Northern VA
Power Trac 1845 and 425
60\" Mower Blade Tip Speed.
I remember a conversation several months ago about the hypothetical blade tip speed of the Power-Trac 60" mower. As part of the belt post, I looked up the speed of the Gresen motor at 8 rpm. I believe this speed to be 3187 RPMs based on 1000 RPMs for each 2.51 GPMs flow. The length of the Power-Trac blade is about 20.5 inches. Therefore the circumference of the blade turning one complete revolution is 20.5" X 3.1459, or 64.49". Multipling 64.49" X 3187 and dividing by 12 yields 17,128 Feet per Minute blade tip speed. Correct?
/ 60" Mower Blade Tip Speed. #2
Re: 60\" Mower Blade Tip Speed.
that would seem correct to me - also that is not that bad
- the fastest commercial ones are 18500 fpm but that is for the larger decks with 25inch blades
/ 60" Mower Blade Tip Speed. #3
Everything looks good to me.
Now why didn't PT know this specification. Last fall I called them about the 425's 60" deck, they weren't able to answer this. Since 17k'/min is pretty good, you think they would include this in there specifications.
Thanks, you answered a I've been wanting to know.
2021 John Deere 2530L Applicator (A63109)
2021 John Deere...
2006 STERLING AT9500 6X4 T/A 14FT DUMP TRUCK (A59910)
2006 STERLING...
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A63118)
1995 Ford F-250...
2018 INTERNATIONAL LT DAY CAB TRUCK TRACTOR (A59911)
2018 INTERNATIONAL...
JRB 52" HANG-ON WHEEL LOADER FORKS (A63276)
JRB 52" HANG-ON...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
