60 inch MMM maintence
/ 60 inch MMM maintence #1
JWE
SW Pennsylvania
Kubota BX2200
I looked at my MMM maintenance manual and it calls for disassembling the gearbox every two years to replace the two oil seals. That seems like a pretty poor design where you have to completely disassemble the gear box every two years.
Does anyone actually do that? It looks like a significant project to replace the seals. I plan to inspect mine and if they are leaking I will replace them; if not, I will leave them be.
Has anyone replaced the seals?
How big of a job is it?
John
/ 60 inch MMM maintence #3
I'm coming up on the 6th year using my BX, and I have not noticed any leakage at all. I do change the gear box oil every spring. I plan on not worrying about the seals.
Will
/ 60 inch MMM maintence #4
If you were using the deck in commercial service for 6-8 hours a day, the two year seal relpacement might make sense. Maybe buy the seals to keep on hand until it starts leaking. I think the power steering hoses are to be changed at two year intervals also.
/ 60 inch MMM maintence #5
I have over 1000hrs on a 1998 B2400 with an RCK60-24B deck and no oil leaks. I wouldn't worry about it. /forums/images/graemlins/cool.gif
I don't plan to replace the seals unless I see a leak. I was mostly interested in seeing if anyone has had to replace them and how long it took them.
I've owned a fair amount of equipment in my life and I can't recall any manufacturer suggesting that oil seals should be replaced every two years (even with heavy use). That suggests a design deficiency that they are trying to disguise by requiring more frequent owner maintenance.
John
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
2021 John Deere 4044M (A64126)
2021 John Deere...
Kubota Diesel Utility Tractor (A62679)
Kubota Diesel...
YALE FORKLIFT (A63291)
2003 International 4300 Flatbed Dump (A62613)
2003 International...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
