6 leaf slipper spring suspension ??
   / 6 leaf slipper spring suspension ?? #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
I am going to buy a PJ trailer (20ft)this weekend per my previous post.Could someone please enlighten me on what a 6 leaf slipper spring suspension is?How does it compare to a torsion suspension?Thanks for any information.coobie
   / 6 leaf slipper spring suspension ?? #2
The slipper spring suspension is the usual spring suspension installed on larger trailers. The leading edge of the spring leaf is attached to the spring hanger with a bolt. The trailing edge is an extended leaf that is not attached with a bolt. As the spring flexes the trailing edge slides along the spring hanger. This system works very well. I have it on my cattle trailer ('81 model) and my dual tandem flatbed ('99 model with 12,000# axles).
I've heard good and bad about the torsion axle. It's really an independent suspension. Each wheel and axle stub moves independently. The axle stub is mounted inside the axle tube with rubber. With time the rubber can wear out.
Thanks for the info JESSE1,I just sold my 16ft hurst trailer,it has the torsion axle(3500 lbs axles).The new PJ trailer (20ft.)has 7000 lbs axles with the slipper suspension.I have never heard of a slipper susp.before,thanks.coobie
2018 Chevrolet Camaro 1LT Coupe (A51694)
2018 Chevrolet...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2000 Ford F-150 Pickup Truck, VIN # 1FTRX17W7YNA75070 (A51572)
2000 Ford F-150...
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
1275 (A50490)
1275 (A50490)
