Snow 6' blade on my GC1720 ok?
   / 6' blade on my GC1720 ok? #11
I have a GC2610. I bought a six foot box blade that is too big but still useable. To plow snow, I got tired of using the oem bucket as it was too slow so I fabricated a new one six feet wide and six inches deeper. Works great.
   / 6' blade on my GC1720 ok? #12
I've been using a 6' back blade on my gc2310 for the last 10 years for snow, gravel, dirr and managed to bent the blade a tiny bit. In other words, I don't think it's too big for your rig. Note that I use a good set of tire chains as this will probably be your biggest limitation; traction. Box blade is a different story.
My two cents.
   / 6' blade on my GC1720 ok? #13
Grade, and tire type will affect your ability to push snow.
My property is flat, and I have turf tires. I also leave the backhoe on for ballast.
If you have hills, and ag tires, it will be more challenging.
As far as pulling snow goes, I haven't tried. But clearly, you will create traction issues if it is deep enough to build up behind you.
If you need to, you could also cut the plow down so it is not as wide.
You may also find, the three point hitch is not set up to be able to lift the blade very high. This is because subcompact tractors need a slightly modified version for maximum performance. This is generally referred to as "BX" series implements.
You can modify the attachment points to make it work better on your tractor, if necessary. Such as, moving the attachment pins, on the bottom, to the inside of the a frame.
pardon my lack of knowledge but doesn't your backhoe get in the way of your 3 pt hitch? You are able to put both on at the same time?
   / 6' blade on my GC1720 ok? #14
Hey all, just wanted to get your take... I bought a 6' Taylor-Way back blade off CL today. Paid $200. Paints peeled and it's got the usual outdoor kept surface rust... Besides wondering if the price was decent, is the 1720 able to push snow with that size blade? I was looking for a 60" when I found this. With yet another snow coming this weekend, I jumped. I have a 100' of asphalt drive, and a quarter mile of gravel to clear a path in.
decent price
looks fine
should work ok I have used one on my little B2150 without much trouble and your tractor has a teeny bit more power than that.
I do a 1/4 mile gravel driveway but pull forward with it angled as other reader said.
Anyway you already have it. Try it out and see how you like it.
Good luck you should be fine. If you are worried don't let much snow build up before you start dealing with it.
Depending on the type of snow you can turn the blade around and pull it forward and it won't hold as much snow.
   / 6' blade on my GC1720 ok? #15
In my post prior to the one you highlighted, I indicated that I have a loader mounted plow.
   / 6' blade on my GC1720 ok? #16
Oh sorry
now it makes sense and the hoe should add a fair amount of weight for traction
looks like a good setup
Used the blade today! It worked amazingly well. Never felt underpowered. Pushed a couple neighbors drives too. I pushed backwards on the asphalt and drives. I pulled it on the gravel. Very impressed with the GC’s ability to control it! Most of all it was fun ��
   / 6' blade on my GC1720 ok? #18
Great!!!
   / 6' blade on my GC1720 ok? #19
Oh sorry
Yes, If you have land that is flat, it's a great.
I can power through anything.
   / 6' blade on my GC1720 ok? #20
Jeez-- don't let it get out that it's fun! This is WORK, man! :)
Bucket of New Caulking (A57454)
Bucket of New...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
Garbage Truck (A59230)
104" PIN ON WHEEL LOADER BUCKET (A58375)
104" PIN ON WHEEL...
JOHN DEERE 750 (A58214)
JOHN DEERE 750...
2004 Thomas Bus (A57148)
2004 Thomas Bus...
