5w-30 synthetic
   / 5w-30 synthetic #1
stevemcg
Have a x485 with 325 hrs. Has been run since new with JD 10-30 non synthetic. Want to run 5-30 synthetic year round. Will this cause any problems? Thanks.
   / 5w-30 synthetic #2
No, you will be fine.
   / 5w-30 synthetic #3
Wow! Only one minute this time!
Mike is the "Domino's Pizza" of the oil forum...
Your synthetic oil question answered in 30 minutes or less! /forums/images/graemlins/grin.gif
   / 5w-30 synthetic #4
Hello Andy, I enjoy mike's comentary on this oil subject. I feel like I know a little more about the oil I use since reading on here. One thing that he differs with some on is that he uses syn form hour one, so rings must seat with the syn just fine. I like useing long drain oils, getting to old and tired to service aa lot. Luck to you......teddy
   / 5w-30 synthetic #5
Just curious...
What CH or CI rated Heavy Duty Motor oil comes in a 5W30 Blend either in synthetic or conventional? I have never seen one...........
   / 5w-30 synthetic #7
you got it. Wherever there is an oil post, I will be there at lighting speeds! /forums/images/graemlins/grin.gif
   / 5w-30 synthetic #8
Good job Mike. You've helped educate quite a few of us on this forum. When I first joined TBN I saw the oil forum section, and thought what a snooze ....oil is oil. Now it's one of the first forums I check when visiting TBN.
My blackstone oil test kit should be here anytime. I'll be sending in my first oil analysis. I think having records of oil analysis when selling a vehicle will be quite impressive to any potential buyer.
Thanks for the education!
Moon of Ohio
   / 5w-30 synthetic #9
yup, I know when I traded in my truck for my Lexus the head mechanic that bought it was a amazed on my records. He could not believe I had oil tests let alone the stuff I did…
   / 5w-30 synthetic #10
5w-30 is what's recommended for my JD 4010 diesel. Just switched to synthetic on it at 13.5 hours.
Use 5w-30 in all but the Benz and the Gravely, including all other air-cooled engines. Use a mix of 5w-30 and 15w-50 on those to get the 10w-40 that they seem to want.
Ralph
2016 Freightliner M2 106 Medium Duty 26FT Box Truck (A51692)
2016 Freightliner...
ALLISON TRANSMISSION (A53843)
ALLISON...
2009 40ft High Cube Refrigerated Storage Container (A51691)
2009 40ft High...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
2015 Freightliner Cascadia 125 T/A Wet Kit Day Cab Truck Tractor (A51692)
2015 Freightliner...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
