5w-30 synthetic
   / 5w-30 synthetic #1
stevemcg
Have a x485 with 325 hrs. Has been run since new with JD 10-30 non synthetic. Want to run 5-30 synthetic year round. Will this cause any problems? Thanks.
   / 5w-30 synthetic #2
No, you will be fine.
   / 5w-30 synthetic #3
Wow! Only one minute this time!
Mike is the "Domino's Pizza" of the oil forum...
Your synthetic oil question answered in 30 minutes or less! /forums/images/graemlins/grin.gif
   / 5w-30 synthetic #4
Hello Andy, I enjoy mike's comentary on this oil subject. I feel like I know a little more about the oil I use since reading on here. One thing that he differs with some on is that he uses syn form hour one, so rings must seat with the syn just fine. I like useing long drain oils, getting to old and tired to service aa lot. Luck to you......teddy
   / 5w-30 synthetic #5
Just curious...
What CH or CI rated Heavy Duty Motor oil comes in a 5W30 Blend either in synthetic or conventional? I have never seen one...........
   / 5w-30 synthetic #7
you got it. Wherever there is an oil post, I will be there at lighting speeds! /forums/images/graemlins/grin.gif
   / 5w-30 synthetic #8
Good job Mike. You've helped educate quite a few of us on this forum. When I first joined TBN I saw the oil forum section, and thought what a snooze ....oil is oil. Now it's one of the first forums I check when visiting TBN.
My blackstone oil test kit should be here anytime. I'll be sending in my first oil analysis. I think having records of oil analysis when selling a vehicle will be quite impressive to any potential buyer.
Thanks for the education!
Moon of Ohio
   / 5w-30 synthetic #9
yup, I know when I traded in my truck for my Lexus the head mechanic that bought it was a amazed on my records. He could not believe I had oil tests let alone the stuff I did…
   / 5w-30 synthetic #10
5w-30 is what's recommended for my JD 4010 diesel. Just switched to synthetic on it at 13.5 hours.
Use 5w-30 in all but the Benz and the Gravely, including all other air-cooled engines. Use a mix of 5w-30 and 15w-50 on those to get the 10w-40 that they seem to want.
Ralph
2013 PETERBILT 388 VACUUM BOBTAIL (A53843)
2013 PETERBILT 388...
RYOBI 18V BRUSHLESS ELECTRIC 20" PUSH MOWRE (A51248)
RYOBI 18V...
UNUSED AGT TSOCPF48 MAST W/ 48" FORKS (A51248)
UNUSED AGT...
UNUSED RAYTREE RMH680 HYD HAMMER (A51248)
UNUSED RAYTREE...
ALLIANCE 15' HEAD CARRIER (A51247)
ALLIANCE 15' HEAD...
2025 AGT YC-26G (A50123)
2025 AGT YC-26G...
