5k Zero Turn Question
/ 5k Zero Turn Question #41
Oh, by the way, the old Allis B, a fifty year old tractor was purchased for less than 10% of the 5K budget, a savings that will get anybody's attention... and I see plenty more of them for sale in the $1k to $1400 range. I considered adding a woods mower to the tricycle front end Allis C that I have because it will turn around in such a small area, durn close to a zero turn. Plus not having front wheels in the way when I pull up to a tree or bush allows the deck to mow right up against them. Might have to look further into that.
David from jax
/ 5k Zero Turn Question #42
I'm in the camp that thinks that 5 K is a lot to spend on a lawn mower. Especially for an acre or so. I've looked at the ZTMs plenty and just can't get past the price and the fact that it is pretty much dedicated to lawn mowing. I know you said that a SCUT was a little bit out of your price range right now, but since you live in snow country have you considered something like the John Deere X320 lawn tractor with a mower, snowblower and cab? That might not be too far away from your budget target. Then you can get summer and winter use out of it. Plus the ability to drag a garden cart around to be helpful with the spring and fall cleanup chores.
Just my :2cents:
/ 5k Zero Turn Question #43
Sandman - and JohninCT. you are both right.
Sandman, on open flat field of grass and no obstructions any 5' or 7' RFM or finish mower will cut as fast or faster for the $ as a ZTM. Then factor in you can buy a real tractor 18-20HP diesel or gas 50 years old and mower for $3K.
John, I agree, get a GT like the x320 or similar or a Cub Cadet 3000 series used for $2500-3000 range and have a multi purpose machine for all seasons.
Carl
/ 5k Zero Turn Question #44
I got the 0-turn cause I mow the parents place and they have several trees,its around 2miles to get there, off%20to%20mow%20parents.jpg. Mine I just use it to get up around house then mow the rest withmowing%20yard.jpg,so I also agree on open areas it will smoke the zero turn:D
/ 5k Zero Turn Question #45
Front deck Zero Turns are still the handiest. A little more money but will cut your trimming time in half easy. Can go around trees and other obstacles without losing time, are safer on slopes than any kind of upright tractor due to lower CG, more accessible deck for easier cleaning and blade sharpening, no running over grass before you mow so you get a more even cut, and for $5k you should be able to buy a mower that will last you 30 years and you will appreciate the convenience.
I had two mowers at this house in the 1st six years before I went Zero Turn 14 years ago. ZTM is as good as new and other than tires and blades it is totally original so virtually no costs. I see no reason why it will not go another 14 years. Well worth the cost.
I do have a Ford 60" RFM for sale if anybody is interested. Hasn't been used for a long time until last year I got it out and made sure it would run well.
/ 5k Zero Turn Question #46
It seems that most people that knock ZTR's have never used one. They are a well designed purpose built machine that will smoke a lawn tractor in any mowing situation.
RFM's are another story.....
The original owner of the property I am buying has now decided to sell his 2011 John deere z445 54" mower if I'm interested. Anyone have any thoughts on that machine ?
/ 5k Zero Turn Question #49
I looked at JD ZTR's last fall and I was NOT impressed with what yopu get for your money:0(
That Z445 retails for $4999 and I was looking at the Z655 series 54" and the MSRP was $6149. Both of these "Residential" ZTR's have stamped decks and sealed(non-serviceable) Tuff-Torq unitized trannies. For just a "little more" than the Z655 I got my 52" Gravely Pro-Turn XDZ 100 with a Kawasaki engine, 7-gauge lifetime warranted fabricated deck, commercial cast iron spindles(witha a 3YR Warranty) and Hydro-Gear ZT3400 Commercial(serviceable) trannies(not to mention mine has a foldable ROPS and a 3Year/1000 Hour Residential or 2Year/1000 hour Commercial Warranty). All that for "a few hundred dollars more than the JD....a no brainer!!! If he wants to sell you that 2011 Z445 for $2,000 it might be worth it, but he'll most likely want closer to $3K at least.
/ 5k Zero Turn Question #50
In general they must be a pretty good mower by the reviews but the first review caught my eye. He gives it five star rating but then says "hard to access belts" and "Engine difficult to get to" - why would he know about either of those after only two years?
I much prefer a front deck but I would say this is probably a $3k value if it is what you want.
/ 5k Zero Turn Question #51
/ 5k Zero Turn Question #53
I could tell you all about Dixie Choppers, but they are out of your price range.
They are supposed to be one of the fastest, but like some say, you don't always cut at your fastest speed.
I have used them for over 30 years, and the reliability is excellent.
I could fix any part of those mowers, even to replacing an engine in about 1 hour.
I also have two Trac Vacs that mount on the rear of the Choppers.
/ 5k Zero Turn Question #54
Read the thread below for a recent John Deere Z425 owner's experience with only 200 hours on it:0(
http://www.tractorbynet.com/forums/general-lawn-garden/287275-bad-boy.html
/ 5k Zero Turn Question #56
I have read a few/isolated bad owner experiences with the Dixie Choppers, but overall I would recommend them over a lot of other brands(like John Deere, Bad Boy and several others). I actually consider the Zee 2 series as a very good bang-for-your-buck Residential ZTR. What DC's have you owned and what do you currently have. There weren't any DC dealers in my area when I was shopping last fall or I definitely would have included them in the mix I was considering!!
/ 5k Zero Turn Question #57
I have two 60 in Choppers with Kohler 25 HP engines and two 42 in with 18 hp Kohler Magnums that need some work.
I had a fast track DC 60 in but sold it.
I would have to say that if anyone had trouble with a DC, they did not know how to use them or work on them.
I also like the gator blades for leaves.
I started out with Snapper 30's and 32's, but they could not handle hills well.
/ 5k Zero Turn Question #58
I don't know whether you're kidding, or serious, but anyway I'd disagree; 7 mph is plenty of speed for most people and I sure don't consider a 7 mph machine to be a waste of money.:laughing:
Yeah,HE ONLY HAS ONE ACRE OF GRASS TO CUT.
2015 Kubota RTVX1100C (A62177)
2015 Kubota...
DAYTON 110,000 BTU OIL FIRED HEATER (A64276)
DAYTON 110,000 BTU...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2013 WYLIE WATER TRAILER (A65643)
2013 WYLIE WATER...
2022 FORD F-450XL FLATBED TRUCK (A64277)
2022 FORD F-450XL...
KUBOTA KX033-4 EXCAVATOR (A65053)
KUBOTA KX033-4...
