5E series 3 Point hitch won't lift
   / 5E series 3 Point hitch won't lift #1
crowbar032
Moores Hill, Indiana
MF 150, TO-35, John Deere 5065E, Caterpiller 953 track loader, NH LS170 Skid Steer
So after a weekend of heavy mowing, the three point hitch on my 5065E won't lift the mower. It has plenty of hydraulic fluid in it. The loader still works and will pick the front of the tractor up off the ground. The third outlet still works as it should. With no weight on the 3-point hitch it raises and lowers fine while the tractor is running. When I shut it off, the arms drop fast as seen in the video. I assume the same hydraulic pump powers all three. I assume that I've blown an o-ring or a filter is clogged. Has anyone else had this issue? Any advice on what to take apart first?
565E 3 pt hitch issue - YouTube
   / 5E series 3 Point hitch won't lift #2
do you have the draft control knob adjusted to far to the sensitive side?
   / 5E series 3 Point hitch won't lift #4
If you pull the 3pt all the way back and then pull the draft control back does it do anything? When messing with it is the draft lever all the way forward? If it's neither of those than my guess would be the linkage might need to be adjusted. I've been down this road. I'm sure it's something simple
Brett
   / 5E series 3 Point hitch won't lift #5
On mine it was the little knob that controls the up/down speed of the 3-point. It somehow got turned all the way to the off position.
   / 5E series 3 Point hitch won't lift #6
In the video it appears similar to when draft control is in "float". I have a 5093e and think our set up is similar. Maybe cycle position control, draft position and rate of drop knob , each ,from each extreme. If a bypass valve is hanging open then it MAY cycle through the pressure and flow rate changes. When I use rotary cutter in 540e for extended time my draft control knob loosens and migrates back. Good luck.
Brett
Four comments about the Draft control float. I'll be checking this tonight. I truly hope it is this simple.
   / 5E series 3 Point hitch won't lift #8
It's sure worth a shot if it fixes the problem!
As suggested, I went home last night and tightened the draft float screw. And the 3 point picked up as it should. Thanks for the replies, this issue is closed. Happy tractoring.
   / 5E series 3 Point hitch won't lift #10
Woo hoo! :drink::thumbsup: Glad we could save you a trip to the dealer!
UNUSED 72" HYD ROCK GRAPPLE BUCKET (A51248)
UNUSED 72" HYD...
2018 DRAGON 130BBL VACUUM TRAILER (A53843)
2018 DRAGON 130BBL...
2018 JOHN DEERE 50G EXCAVATOR (A51246)
2018 JOHN DEERE...
Trojan 35CL 40 mm Hydraulic Hammer, NEW (A52384)
Trojan 35CL 40 mm...
2016 Wells Cargo Enclosed Trailer (A53117)
2016 Wells Cargo...
