585 jumping out of gear
   / 585 jumping out of gear #1
valton
new zealand
ford 6610
I Have a 585 that had been sitting unused for more than a year, and when I got it started up it wont move off if there is any weight on it if I ease the clutch out but will if I drop the clutch. Any ideas?
   / 585 jumping out of gear #2
Sound like a problem with the clutch, probably with sitting for a while there may be some rusting on the splines.
Sound like to fix you will need to split tractor and derust splines etc then apply special lubricant to clutch shaft and disc splines
You ca n remove an inspection plate below the clutch housing and have a look at what is going on!!
Toro Sand Pro (A56859)
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A58214)
2014 DRAGON...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2019 Ford F-150...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56435)
2012 MACK Tender...
NEW Landhero Mini Excavator (A59000)
NEW Landhero Mini...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
