585 jumping out of gear
   / 585 jumping out of gear #1
valton
new zealand
ford 6610
I Have a 585 that had been sitting unused for more than a year, and when I got it started up it wont move off if there is any weight on it if I ease the clutch out but will if I drop the clutch. Any ideas?
   / 585 jumping out of gear #2
Sound like a problem with the clutch, probably with sitting for a while there may be some rusting on the splines.
Sound like to fix you will need to split tractor and derust splines etc then apply special lubricant to clutch shaft and disc splines
You ca n remove an inspection plate below the clutch housing and have a look at what is going on!!
Harley Davidson (A56859)
Harley Davidson...
2017 CATERPILLAR 304E2 CR EXCAVATOR (A52709)
2017 CATERPILLAR...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A56436)
2019 Krause...
2003 Big Tex 10PI...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
2020 Ford (A55973)
2020 Ford (A55973)
