585 jumping out of gear
   / 585 jumping out of gear #1
valton
new zealand
ford 6610
I Have a 585 that had been sitting unused for more than a year, and when I got it started up it wont move off if there is any weight on it if I ease the clutch out but will if I drop the clutch. Any ideas?
   / 585 jumping out of gear #2
Sound like a problem with the clutch, probably with sitting for a while there may be some rusting on the splines.
Sound like to fix you will need to split tractor and derust splines etc then apply special lubricant to clutch shaft and disc splines
You ca n remove an inspection plate below the clutch housing and have a look at what is going on!!
White Metal Roof Panels (A55758)
White Metal Roof...
2013 POLAR TANK TRAILER CRUDE TRAILER (A58214)
2013 POLAR TANK...
CABINET OF HOSE ENDS (A58214)
CABINET OF HOSE...
2022 Ford F-450 Super Duty STX Pickup Truck, VIN: 1FT8W40T2NEC20764, Crew Cab, 4x4, Fx4 Off Road, (A59076)
2022 Ford F-450...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2025 GPS Trailer (A56859)
2025 GPS Trailer...
