580K flood light problem
/ 580K flood light problem #1
Frank J
Downingtown, Pa.
Case 580K
Anybody know if there is a relay for the flood lights on a 580K case backhoe. Flood lights stopped working.
/ 580K flood light problem #3
Hi and welcome. If not the fuse most likely a wire connection is loose or wire broken. I have had bad connections in the fuse holder as well.
Good luck
/ 580K flood light problem #4
Don't know of a relay either, could check a parts diagram to narrow down. Id say same as dave. I had a switch problem, and if I remember correctly theres 2-3 different switch positions with lights and flashers.
MERRITT ALUMINUM HEADACHE RACK (A64277)
MERRITT ALUMINUM...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
HYUNDAI HL770-9A WHEEL LOADER (A65053)
HYUNDAI HL770-9A...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
