580K flood light problem
/ 580K flood light problem #1
Frank J
Downingtown, Pa.
Case 580K
Anybody know if there is a relay for the flood lights on a 580K case backhoe. Flood lights stopped working.
/ 580K flood light problem #3
Hi and welcome. If not the fuse most likely a wire connection is loose or wire broken. I have had bad connections in the fuse holder as well.
Good luck
/ 580K flood light problem #4
Don't know of a relay either, could check a parts diagram to narrow down. Id say same as dave. I had a switch problem, and if I remember correctly theres 2-3 different switch positions with lights and flashers.
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
Wolverine Quick Attach Trencher (A66408)
Wolverine Quick...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
2019 Carry On Dump Trailer (A62613)
2019 Carry On Dump...
2019 Lynco Mini Mover Aircraft Tug Cart (A64553)
2019 Lynco Mini...
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
