580K flood light problem
   / 580K flood light problem #1
Frank J
Downingtown, Pa.
Case 580K
Anybody know if there is a relay for the flood lights on a 580K case backhoe. Flood lights stopped working.
   / 580K flood light problem #3
Hi and welcome. If not the fuse most likely a wire connection is loose or wire broken. I have had bad connections in the fuse holder as well.
Good luck
   / 580K flood light problem #4
Don't know of a relay either, could check a parts diagram to narrow down. Id say same as dave. I had a switch problem, and if I remember correctly theres 2-3 different switch positions with lights and flashers.
2014 Ford Taurus AWD Sedan (A51694)
2014 Ford Taurus...
More info coming soon! (A50323)
More info coming...
2016 GMC 2500HD SERVICE TRUCK (A51406)
2016 GMC 2500HD...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
SET OF (4) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (4) ALCOA...
eXmark Quest Zero Turn Mower (A53117)
eXmark Quest Zero...
