580D water pump
/ 580D water pump #1
Bill Barrett
Platinum Member
midwest
Kubota L3130, Satoh G650, Case 580, Case 446
I have a 580D TLB with the 207 engine. Its overheating with a new thermostat installed, take it out runs cold. I think the water pump has lost capacity. Is there any way to check it's output? Is this a common thing?
Thanks
/ 580D water pump #2
I'd take the thermostat out and heat up some water and put it in and see if it infact does open,, I'd also double check to see it was installed in the right direction ( no dis intended ), just covering possibilities.
/ 580D water pump
yep did that, now I have it together without the thermostat, runs cold. Thermostat is fine.
3012SFL (A61567)
3012SFL (A61567)
2017 KOMATSU D61PXI-24 CRAWLER DOZER (A64279)
2017 KOMATSU...
John Deere 6200 Tractor (A64047)
John Deere 6200...
300 GALLON FUEL TANK W/MANUAL PUMP (A64281)
300 GALLON FUEL...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
2009 Arco Trailer 6,000 Gallon T/A Tank Trailer (A61568)
2009 Arco Trailer...
