580D water pump
/ 580D water pump #1
Bill Barrett
Platinum Member
midwest
Kubota L3130, Satoh G650, Case 580, Case 446
I have a 580D TLB with the 207 engine. Its overheating with a new thermostat installed, take it out runs cold. I think the water pump has lost capacity. Is there any way to check it's output? Is this a common thing?
Thanks
/ 580D water pump #2
I'd take the thermostat out and heat up some water and put it in and see if it infact does open,, I'd also double check to see it was installed in the right direction ( no dis intended ), just covering possibilities.
/ 580D water pump
yep did that, now I have it together without the thermostat, runs cold. Thermostat is fine.
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
