575 DI
/ 575 DI #1
abritton77
I just recently bought a 97 575 DI. I have noticed that the pto shaft appears to be slightly bent. I really dont think it is bad enough to matter but am wondering what it would take to fix it and what a new shaft would cost. Any help would be appreciated.
Are these good tractors? It seems to be ok to me.
/ 575 DI #2
Don't operate it with a bent shaft. Doing so will destroy the gear set inside the tractor! You want no vibrations!
/ 575 DI
Now my diff lock is stuck in the engaged position. I am starting to wonder if I messed up by buying this. Has anybody had this happen before.
/ 575 DI #4
Try backing up .... also get on blacktop and turn, back etc... you should hear it pop and come undone.
/ 575 DI
the rod that engages the diff lock is stuck in. i am afraid that if i put it in a bind, somthing will break. what do you think?
/ 575 DI
I tried turnning on my concrete drive while working the nob and backing up while doing the same thing. Ive tried clamping vicegrips on the shaft to pull it out but cant get it out no matter what. I think that I am going to pull the hydraulic assembly off so I can get to the clutch and replace all of the worn and damaged parts. While I am at it I am going to fix the pto shaft. After this, I think I will have a very good tractor I hope. Even after spending 500 on parts, I believe this is the best tractor that I could afford and I could probably get my money back this spring if I decide to sell it.
/ 575 DI #7
The 575DI is a good tractor. I have a 485 DI. Good, simple, and generally reliable machines.
Have you tried penetrating oil on the diff. lock rod?
/ 575 DI
Ive got my 2 problems solved but have another question. Just below and slightly foward of the clutch pedal there is a lever that has 3 positions labeled as high med and low I think. Does anybody know what this does?
/ 575 DI #9
The lever is the PTO High-Low Range Speed Selector Lever. Not something I would see you adjusting.
/ 575 DI #10
This is good info. I too just bought a 575DI with a leaking fel ram.
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
John Deere RM 12R Cultivator (A66285)
John Deere RM 12R...
2017 VERMEER TG7000 TUB GRINDER (A66091)
2017 VERMEER...
2005 KENWORTH T800 T/A 6X4 DAY CAB TRUCK TRACTOR (A67147)
2005 KENWORTH T800...
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
Lot 602 (A62613)
Lot 602 (A62613)
