5740C 4 wheel drive doesn't engage
   / 5740C 4 wheel drive doesn't engage #1
Ron Henderson
Hi,
I have a 5740 with 400 hours that the 4 wheel drive has quit working. No noises, it just doesn't work.
I drove down into the woods to clear some trees I had cut down and got stuck trying to go uphill in some pine straw, only the rear wheels were pulling.
After I managed to back up using the front end loader I drove to shop and begin to trouble shoot.
The linkage operates correctly so I assume it's internal.
Anyone else had this problem?
Looks like I will have to drop the fuel tank to allow room to pull the side off the transmission.
Thanks,
Ron
   / 5740C 4 wheel drive doesn't engage #2
Sorry Ron, I have had 5740C since 2005 and have never had this problem. Good Luck and I wish you the best.
Eureka, I got my 4WD fixed! All it took was a couple of phone calls and $237 including shipping.
I started by checking the parts diagrams here Parts For Montana Tractors.
I then called and talked to a guy there that has a good bit of experience with these tractors.
He told me the easiest thing to check and most common is stripped splines on the front 4WD shaft.
He was right, I had to buy a new shaft, a coupler, and 2 new roll pins. The shaft is coupled at the front and rear.
The shaft runs through a housing held in place by 1 bolt at each end, the front of the housing collapses to the rear. This gives you room to drive the old roll pins out and un- couple the shaft for removal.
I was very surprised at the amount of rust on the shaft and spines, not sure how this is lubed, maybe it's not.
When I put the new one in today I applied lots of grease all over.
Kind of pricey, but, my tractor has to have 4WD, without it I get stuck a lot !
Ron
   / 5740C 4 wheel drive doesn't engage #4
Glad you got it fixed.
Dies the rear axle have a locking differential? That should assist you getting out of a stuck situation if it happens again. I engage the locking diff when I go through swampy/muddy areas, even with 4wd engaged
It does have a locking differential, which does help.
I think the main problem is the rear tires are industrial tread unlike the deep V type in farm applications. They spin quite easily.
Ron
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2016 HINO 268 26FT BOX TRUCK (A51222)
2016 HINO 268 26FT...
1986 John Deere 772B Articulated Motor Grader (A49461)
1986 John Deere...
2018 Terex RL4 4000W Towable Light Tower (A49461)
2018 Terex RL4...
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A51039)
2024 Ford F-350...
