radman1
Elite Member
- Joined
- Jul 8, 2006
- Messages
- 3,017
- Location
- midwest
- Tractor
- JD 4520, Toolcat 5610, Bobcat S300, Case-IH 125 Pro, Case-IH 245, IH 1086, IH 806
Other specs include 3180 psi for the rear remote couplers. 3000 psi for the front auxillary couplers. Relief setting for the 3 pt and tilt cylinders is 3335 psi.
I made an error in an earlier post. The relief settings for both the front aux hydraulics, tilt, lift and rear 3 pt is the same. The relief setting is 3045 psi. There are 2 separate relief valves on the main hydraulic control valve. One for the auxillary hydraulics (front) and the other for the lift, tilt and 3 pt.
(The port relief/anticavitation valve setting for the lift, tilt and 3 pt is 3335 psi.)
The 3180 psi for the rear couplers is correct. This uses a different valve and relief than the main hydraulic control valve.
